SailNet Community - View Single Post - CDI Furler Halyard is Getting Stuck
post #6 of Old 06-12-2013 Thread Starter
caberg
caberg's Avatar
Re: CDI Furler Halyard is Getting Stuck
if the halyard by itself is dragging/stuck then it's most likely off the pulley at the top of the foil...
The halyard by itself is dragging/stuck, and this is what I am afraid of. Conceptually, this would make sense. However, it appeared we had the same problem last season, and within 10 minutes the sail did eventually go up.
There's probably no way to determine if it's the above issue without going up the mast to have a look-see?
Not sure if it makes a difference, but I believe mine is the Flexible Furler, and more specifically the FF2. http://www.sailcdi.com/sailpdf/FF2%20manual%206_12.pdf
caberg is offline
