SailNet Community - View Single Post - CDI Furler Halyard is Getting Stuck
post #9 of Old 06-12-2013
Azzarac
Azzarac's Avatar
Re: CDI Furler Halyard is Getting Stuck
Caberg, I'm assuming on your 26 you are using the CDI FF2 and are referring to the internal halyard. If so, take a close look at the furler luff. Is there any twist or bend? If so that is where your problem lies. I just replaced mine this spring because it was so distorted from 16 years in the desert sun I could no longer move the carrier through the channel without a hammer and screw driver to assist in the operation. Here you can see the new one compared to the old side by side:
“If you surrender to the wind, you can ride it.” – Toni Morrison
"Sic gorgiamus allos subjectatos nunc"
Follow Chameleon's travels at:
Azzarac is offline
