SailNet Community - View Single Post - Bob Perry's take on Wolfenzee's dream boat
post #627 of Old 06-17-2013 Thread Starter
Jeff_H
Moderator
Jeff_H's Avatar
Re: Bob Perry's take on Wolfenzee's dream boat
A good sailmaker should be able to advise you, but your boat has a lot more drag and a lot more weight than most modern designs. Because if that the sail cloth would want to be slightly on the heavy side for a 30 footer and the sail cut slightly 'powerful' rather than flat cut. You do not want to over do the power since your boat is initially a little tender. You will want a 'hard, dense weave, cruising cloth' rather than a 'soft cruising cloth'.
If you are going offshore on a regular basis, you will want seams with the cloth lap edges folded and stitched under (it adds weight and harms sailing ability, but stands up better to flapping.) If you are going to the tropics, there are threads which have better UV characteristics and you may want to opt for them. You will want spreader patches on all your sails, and you can add stick on chafe cloth where the seams touch the shrouds when reaching. You will want oversided reef patches and heavy webbing reinforcement on your clew and reef clew grommets. You will want full length battens set horizontal so that they do not jamb and you can avoid a custom track on the mast.
If you do not have a vang, make sure that your sail maker knows that since the sail will have way more twist than ideal. (Another reason to have full length battens) You will probably want a loose footed mainsail since you are singlehanded and it makes R&R-ing the sail way easier. You may want a spectra strop at the clew to reduce stress on the boom.
You may want a single reef on the foot of your genoa if you do not gave furling and guide rings for a downhaul on your hanks.
That is all that comes to mind....
Jeff_H is online now
