SailNet Community - View Single Post - Viewing a Bristol 32 tonight... Questions
post #18 of Old 06-17-2013
seabreeze_97
Re: Viewing a Bristol 32 tonight... Questions
'68 Bristol had aft cockpit traveller, so no issues like the '76 and newer. Decks should feel solid as concrete since they are solid fiberglass (no wood cores). If they don't feel solid, there could be something, but these boats are not known for weak decks. '76 and newer had 4ft reduction in mast height on tall and short rigs, as well as a little less ballast (couple hundred pounds). Boom was about 2 feet shorter. I don't think Universal was an original engine in '68 so you might luck out on the associated hardware, maybe even the fuel tank. If it hasn't been addressed, the most likely source of water in the bilges will be from the hull/deck joint. Bristol used quality hardware, but the joint will leak unless it's been re-sealed. Check for play in the rudder. Though well built, even it will need attention at some point. In cabin look at chainplates and shelves for signs of delamination from water or severe hull abuse (like banging around in a marina during a hurricane). Good luck.
seabreeze_97 is offline
