SailNet Community - View Single Post - Bottom paint on prop
post #30 of Old 06-19-2013
Omatako
Omatako's Avatar
Re: Bottom paint on prop
Originally Posted by jrd22 View Post
Are you sure you are talking about the same stuff Om? This is a spray can, not a litre can that you brush on.
No the stuff I used is brush-on but the spec appears to be the same. The can even looks the same but obviously not aerosol.
Your description in your reply to Fstbttms is exactly what I found under my boat after about 8 months of Trilux - "The Autoprop was a big ball, I couldn't see the blades when I dove it."
I can't recall seeing Trilux in the chandlers here in aerosol - whatever the case I'm going the Propspeed route this time round and will see how it goes.
Thanks
Arthur C. Clarke
Omatako is offline
