SailNet Community - View Single Post - New deck stepped mast for Trintella 42 /USA
post #6 of Old 06-19-2013
overbored
overbored's Avatar
Re: New deck stepped mast for Trintella 42 /USA
the cap shrouds or uppers should line up with the center of the mast more or less. on more modern rigs the caps are set way back and they use swept back spreader. the position of the chain plates and mast base on your boat will be almost inline and uses straight spreaders. the straightness or sweep of the spreaders does depend on the rake of the mast. you will have a back stay on that rig. seems like you might want to consult another rigger if does not understand how your boat was rigged.
"GOLD RUSH" PRINDLE 16
overbored is offline
The Following User Says Thank You to overbored For This Useful Post:
yawlcat (06-20-2013)
