SailNet Community - View Single Post - Feathering Props
Old 01-17-2002
Denr Denr is offline
Senior Nappy Headed Ho
Denr is an unknown quantity at this point
Feathering Props
I have first hand experience with the Martec prop Jeff suggested. These are beautifully machined, stainless steel works of art but, they are VERY heavy. I suggest that you make sure that your entire driveline i.e., motor mounts, transmission, cutlass bearing, stuffing box, coupling and strut are in excellent condition. These props look like they could be "gear busters" if everything is not in top condition.
Also check the material of your shaft, it is most likely bronze. Periodic removal of the propeller will be easier if the prop and shaft are made from similar materials. If your shaft is bronze, go for the MaxProp.
