SailNet Community - View Single Post - Epoxy screws
Thread: Epoxy screws
post #3 of Old 06-21-2013 Thread Starter
davidpm
davidpm's Avatar
Re: Epoxy screws
Originally Posted by Minnewaska View Post
Did you use epoxy that is meant to be underwater?
I used west system and plan on doing a very rough job of coating with gel coat.
http://www.westsystem.com/ss/assets/...2Polyester.pdf
I'm just using what I have on hand.
The boat is dry sailed anyway.
The way I understand it most epoxy is ok underwater but the underwater stuff will actually stick and cure better and faster.
Some new boats have vacuum bagged hulls with epoxy, but they are painted of course.
davidpm is offline
