SailNet Community - View Single Post - Epoxy screws
Thread: Epoxy screws
post #8 of Old 06-22-2013 Thread Starter
davidpm
davidpm's Avatar
Re: Epoxy screws
Originally Posted by BarryL View Post
Hey,
I had a similar situation with a old plastic WaterTender dinghy. After years of dragging it up and down the sand the 'skeg' wore though and allowed water to get between the outer and inner plastic. It still floated fine but got real heavy to drag up the beach. I got a few more years out of it by gluing a wood strip onto the skeg.
I tried your solution of epoxy and an aluminum strip but the aluminum was too brittle and broke off. The wood lasted longer but it was hard to get a water tight seal with epoxy.
My ultimate solution was to by a new Watertender 9.4 for $500 (when on sail). I figured it would last 20 years so I would be ok. It was stolen this spring but that's another story.
Good luck,
Barry
This is a fiberglass dinghy so I'm hoping the epoxy will work better.
The aluminum is supported full length and if anything is too soft not too brittle.
I'll probably do what you did, fix it until I can't then buy something else.
davidpm is offline
