SailNet Community - View Single Post - New Honda 2.3 outboard not running
post #5 of Old 06-22-2013 Thread Starter
CaribDream
CaribDream's Avatar
Originally Posted by dabnis:1048053
Sounds like it is starving for fuel. Suggest you make sure the tank vent is not plugged. If not, sounds like some debris got into the carb, or the gas evaporated, leaving goo behind. Maybe some carb cleaner at about 50% gas mix. Let it set for a day or two then try gain. If no go, time to clean out the carb, thin wire and compressed air. Suggest you drain the carb if it is not going to be used for a week or so
Paul T
Exactly what I was thinking - fuel starved. Just can't figure out how something got messed up this early. It's one month old, used 3 times and I always run super instead of regular just like my other boats.
Go sailing now my brother,
It's later than you think.
CaribDream is offline
