SailNet Community - View Single Post - Do you wear a life jacket?
post #25 of Old 06-23-2013
NCC320
Re: Do you wear a life jacket?
I sail inshore, so I generally do not have rough conditions to contend with. I always wear an auto-inflatable belt pack inflatable. Not as good or secure as a vest/harness type inflatable, but very comfortable. You don't even know it's there most of the time. However, it is not as safe as the harness type inflatable in that you have to finish putting it on after you are in the water and part of the process is letting out some of the CO2 to partially deflate it so you can get it over your head. Then you pull the straps tight to finish. You use the mouth piece to re-inflate fully after it's on. If it becomes rough, then I go to an auto harness type inflatable, which I carry on board at all times, also have tethers/jacklines to clip in. I have three of each type on board, plus a bunch of the red foam Type II's.
NCC320 is offline
