SailNet Community - View Single Post - Small outboard plastic prop?
post #3 of Old 06-24-2013
ScottyG24
ScottyG24's Avatar
Is prop aluminum and when u remove it isthe area where the prop shaft goes into the prop rubber? When props get old that rubber breakdown abd it will cause it to slip reducing thrust. If it is not that you are prob just incorrectly pitched. See what the pitch number should be for your propellor beforeyoubuya replacenent. Plastic props are fine and the flex is built in but they dont last forever
ScottyG24 is offline
