SailNet Community - View Single Post - Catalina 22 sail on Capri 22
post #3 of Old 06-24-2013
jameswilson29
Senior Smart Aleck
jameswilson29's Avatar
Re: Catalina 22 sail on Capri 22
The Capri 22 (designed in 1984) is a fractional rigged boat manufactured by Catalina as a racer/cruiser. The forestay does not go to the stop of the mast, but only 3/4 - 7/8 of the way. Sailboats with fractional rigs usually have a bendable mast and an adjustable backstay which allows one to bend the mast, thus flattening and depowering the mainsail.
The Catalina 22 (designed in 1969) is a masthead rig designed as a trailerable cruiser. The forestay/headstay goes to the top of the mast. The mast is rigid and the backstay is not adjustable.
A boat may be rigged with a mast from another boat. Sails can be interchangeable and flown on a number of different boats, as the dimensions allow. However, a mainsail from a masthead rig will likely be cut differently from a mainsail from a fractional rig and may not be as efficient or adjustable.
On this boat, the owner may simply be flying a sail from a different boat, or the mast may have been switched. Does the forestay go to the top of the mast or only 3/4 or 7/8ths of the way? You could also haul a measuring tape up the mast with the jib or main halyard and note the distances to determine whether this is an original mast.
jameswilson29 is offline
The Following User Says Thank You to jameswilson29 For This Useful Post:
JeffH (06-24-2013)
