SailNet Community - View Single Post - Hot Water Heater Usage
post #17 of Old 01-18-2007
georgellop
georgellop's Avatar
WAYMAR83, ...it is imperative that you drain the gray water into a SEALED sump with its own pump and not into the bilge or any open containment area. If not, you will soon be wondering how can shower water smell as bad as black water.
There are shower sumps readily available at places like West Marine. Install a water trap between the shower drain and the sump.
As far as an overboard solution, maybe a manifold on one of the through hulls located above the water line.
re. propane instant water heaters
... can these units, somehow, be installed on deck therefor eliminating the oxygen depletion problem. Would it be sensible alternative to do so?
George.
George Llop
S/Y BANDOLERA
1958 41' PHILLIP RHODES BOUNTY II
BETAMARINE
DIESEL PROPULSION & GENERATORS
Mobile: (786) 443 5567
Fax: (786) 221 3986
georgellop is offline
