SailNet Community - View Single Post - How do I calculate my power needs?
post #12 of Old 06-25-2013
copacabana
Re: How do I calculate my power needs?
Chuckles is right concerning battery monitors. Voltage alone only gives you a very rough idea of battery state. To be effective it has to measure voltage on a "rested" battery, which doesn't happen on a boat. However, if it's what you have to go on... A fully-charged battery should show 12.7 or 12.8 volts. The voltage will drop as you use the battery. At 12.2 volts the battery has only 50% charge and should be charged again. I also use voltage on my boat to monitor batteries, but since I make more power than I use, I don't really worry too much about input-output. My two 75w panels top up the batteries during the day (12.8v) and I might see a voltage before sunrise of 12.6 or 12.5 volts. Not very sophisticated, but it works. You might want to add solar panels and/or wind power and then see how much power you can make. Then tailor your consumption to your power generation. The coffee machine may have to go ...
Vindö 50
copacabana is offline
