SailNet Community - View Single Post - After Winterizing: Fire Up and Go?
post #14 of Old 06-25-2013
Minnewaska
Re: After Winterizing: Fire Up and Go?
If you are running the same impeller that sat in there all winter, I highly recommend changing it. It will work perfectly right up the to second it doesn't work at all and you have to figure out how to get rubber bits out of your heat exchanger.
Not trying to alarm. It's typically a fairly easy job and not expensive. Good insurance.
Jeanneau 54DS
Minnewaska is offline
