SailNet Community - View Single Post - Water leak- plumbing
post #3 of Old 06-26-2013
Joe Choniski
Re: Water leak- plumbing
hi,
Water leaks
If you pay for your water on a meter and suspect your bill is high, this might be because there is a water leak or overflow. You may be paying for water that’s going to waste.
Find out what to do if you suspect you have a water leak and how to work out who’s responsible for fixing it.
How to spot water leaks
It’s possible you may have a water leak if:
you hear the sound of running water
you see running water or wet areas
you see a lot of plants growing near pipe work, especially during dry weather
the water pressure in your home falls.
thank you.
Joe Choniski is offline
