SailNet Community - View Single Post - Anchor Setting Woes
post #13 of Old 06-26-2013
paperbird
But if not...
Re: Anchor Setting Woes
Lots of good advice. To emphasize a couple points:
Danforth is fine for the Chesapeake. We anchored for years with one all over the Bay with no issues. And without all chain. On boats ranging from 22-34'. Yes the new gen anchors are great. Even better with all chain rode. (Yes I do sleep better now). But technique is the key for all anchoring situations. Develop yours and follow it.
Couple things from our practice:
- develop a hand signal system that works for you. We never have to holler back and forth
- put the anchor gently on the bottom with a slight amount of aft way on. Don't let the anchor touch while moving fwd or it will lay down wrong and it's uphill from there
- pull gently initially while at btwn 3 and 5:1 - your choice and some bit of feel involved. Goal is to get the danforth diving into the mud. Once pointed that way, it'll tend to stay that way.
- 5:1 for day, 7:1 for overnight, 10:1 for bad conditions (wind, current, shifts, bottom, etc) - Don't forget water to bow distance. We have scope table taped on the door of the anchor locker. I don't want either or us to screw up our math if we're tired.
- Once scope is out to what you want, pull hard while lining up a range off the beam. I never trust instruments to tell me I'm set. I want to see a range not change
- sit back, relax, and watch your range marks for awhile to make sure.
- ask others in the anchorage how much scope they have out.
- if something isn't comfortable, it's not right. That odd feeling should never be ignored.
paperbird is offline
The Following User Says Thank You to paperbird For This Useful Post:
cman (08-05-2013)
