SailNet Community - View Single Post - 1981 Islander Bahama 30 Topping Lift
post #2 of Old 06-26-2013
Faster
Re: 1981 Islander Bahama 30 Topping Lift
This kind of thing isn't really 'boat specific'... it can be whatever you want it to be.
"wired to the backstay" sounds like a temporary pennant that supports the boom when you're not sailing. It's not as good as a real topping lift because it's not very effective when you want to support the boom while reefing.
A fixed topping lift from the masthead to end of boom, with a short adjustment tackle at the boom end works well, or the TL can be run to the masthead, down the mast and aft to the cockpit for easier adjustment. Either option requires a trip to the masthead to set it up (to add a block or shackle for the lift) if it's not already there.
Faster is offline
