SailNet Community - View Single Post - Good Blue Water / Shallow Water Compromise
post #17 of Old 06-26-2013
capta
Master Mariner
capta's Avatar
Re: Good Blue Water / Shallow Water Compromise
We have a centerboard boat that draws 6 feet when it's up and over ten when down. Six feet is an acceptable cruising depth, though thanks to Regan the ICW has parts that are no longer navigable for a boat that deep. But when fighting for every inch on a windward beat, that 10+ feet of draft is amazing.
Even at anchor we run the board down about 2/3 of the way and it's like sticking a spike into the bottom (it never actually touches the bottom) and we ride so much more comfortably than the shallower draft vessels around us.
I'm not sure if a swing keel is another name for a centerboard, so if not, I can't help you with that.
Another point with a centerboard; it is NOT an all or nothing proposition, experiment with the depth to find the best amount to put down for conditions.
Good luck.
facebook.com/svskippingstone
Our Videos;
capta is offline
