SailNet Community - View Single Post - Capsize Ratio
Thread: Capsize Ratio
Old 01-19-2007
sailingdog sailingdog is offline
It really depends on where you'll be sailing the boat, and under what conditions. A capsize ratio of 2.26 is probably just fine if all you're doing is daysailing and taking short coastal trips on relatively protected waters, where you can get out of bad weather quickly. For offshore use, the number is too high, as it is generally recommended that you have a CR of less than 2.0 for bluewater use, and the lower the better.
