SailNet Community - View Single Post - After Winterizing: Fire Up and Go?
post #15 of Old 06-27-2013 Thread Starter
caberg
caberg's Avatar
Re: After Winterizing: Fire Up and Go?
Thanks, Minnewaska. I am fairly sure this was on the punch-list in the fall when I had the yard winterize the engine, but I will double-check. If it was a new impeller in the fall, should be fine, right? If I visually inspect it will I be able to determine if it needs replacing?
caberg is offline
