My guess is that Deezol is just an alcohol-based additive that emulsifies the water and brings it into solution—getting rid of the water/diesel barrier that is necessary for the growth of algae. Using too much of it might be bad for the rubber and plastic parts in the fuel system... Might want to check that before you go overboard with using the product too much.
