SailNet Community - View Single Post - Anchor Setting Woes
post #29 of Old 06-27-2013
MarkofSeaLife
MarkofSeaLife's Avatar
Dock
Re: Anchor Setting Woes
Originally Posted by GeorgeB View Post
Mark, what is the size of your boat again? And what is the size of your chain and is it standard or proof coil? I will be cruising Mexico and am re-thinking my ground tackle. I currently have a 35# Delta Fastset, 40’ of 3/8 proof coil chain and 250’ of 5/8 rode (nylon 3 strand). I also have a kellet. My boat is 34’ and fully laden for cruising will be about 16,000#.
My boat is a Beneteau 393, 39 feet, 11.62 m, 7.5 tons light and 8.5 tanked.
the chain is 10mm wich is similar but not exactly 3/8th inch. I dont know what standard or Proof coil are... but its the 'normal' chain that most boats get of that size.
I would keep the Delta but add as much chain as you can afford. I havent actually used more than 80 meters any time (260 feet) but its nice to know I have as much as I possibly can.
The 40' and 250 rode would be good for a kedge anchor because its light enough for setting by dinghy. For that anchor I would just get a kedge, so it can be a smaller Delta etc.
By Mexico you mean the west side? Sea of Cortez etc? I havent been there but I understand the anchoring can be quite deep. Thats similar to the Mediterranean where 25 meters water depth is common (80 feet water) now thats a lot of chain you want. If you dont have it then you are more restricted to parking the boat, maybe missing a great anchorage.
If I had oooodles of money I would be getting a Manson Supreme for the main anchor (or whatever new generation is currently winning in the anchor threads!)
I tried a Kellet (bucket of concrete) in a hurricane and it did bugger all good. It popped up like a ping pong ball and was just a twisting mess when we swung around. Useless as boobies on a bull. The weight of the kellet is only about 10 feet of chain anyway.
So now I keep stuff simple: 1 anchor, one long chain, one snubber
Hope this helps
Mark
Sea Life
Notes on a Circumnavigation:
MarkofSeaLife is offline
The Following User Says Thank You to MarkofSeaLife For This Useful Post:
cman (08-05-2013)
