SailNet Community - View Single Post - Yanmar YM oil pressure alarm failure
post #9 of Old 06-27-2013
BellaCoola
Re: Yanmar YM oil pressure alarm failure
Hi CTLOW---Disconnect wires one at a time and see which light does not go on when you turn switch before starting. Your oil sender will be low on your block, probably just near you fill line or above.
I'm trying to find fittings that go metric 10mm to 1/8 pipe standard so I can put an oil pressure guage on too alongside the sender as I have great pressure but sender goes off sometimes , even after changing !!. I know there was a post re this somewhere ????
BellaCoola is offline
