SailNet Community - View Single Post - Yanmar YM oil pressure alarm failure
post #10 of Old 06-27-2013
mark2gmtrans
sailing soon
mark2gmtrans's Avatar
Send a message via Yahoo to mark2gmtrans
Re: Yanmar YM oil pressure alarm failure
The oil pressure sender is located on the engine above the oil filter. It is directly on the block and is slightly below and to the rear of the fuel pump. If you are standing in front of the engine, looking just above the oil filter you should see the wire going to it. If you find it is bad, it is a very simple fix and you should be able to do it in just a few minutes.
You will find the diagrams on page 12 of your owners manual...here
http://yanmar.com/product/marineplea...V2_21JAN09.pdf
Send me a PM if you have further questions.
Mark
It is good to learn from your mistakes, but much better to learn from the mistakes of others...
mark2gmtrans is offline
