SailNet Community - View Single Post - NW FL Liveaboard
post #6 of Old 06-27-2013
mark2gmtrans
sailing soon
mark2gmtrans's Avatar
Send a message via Yahoo to mark2gmtrans
Re: NW FL Liveaboard
Using the prop drag to generate electricity, does the motor act as the generator at that point? Or is it a separate generator driven by the same shaft? Just wondering what the drag loads will be under sail, and how much time under power you will be able to run prior to needing a recharge from one system or the other, basically the amp hour load under power at cruise speed?
Are you planning on long range blue water cruising? Or mostly coastal cruising, daysailing? I have seen a couple of boats for sail that had the electric engines, but since I have never really talked to anyone who had much knowledge on them I had questions that went unanswered...
It is good to learn from your mistakes, but much better to learn from the mistakes of others...
mark2gmtrans is offline
