SailNet Community - View Single Post - battery bank dual charger or triple charger?
post #17 of Old 06-27-2013
LinekinBayCD
Re: battery bank dual charger or triple charger?
Originally Posted by Seaduction View Post
The ACR is simply a switch that combines or disconnects 2 separate batteries or banks of batteries. If the ACR detects a certain charging voltage on 1 bank then it combines the other bank that it is connected to. It disconnects the banks when the voltage drops below a preset level. It cannot set a voltage for battery type; the charger must do that.
Does not sound like it is a better set up than an echo charger. I switch manually between banks based on which needs the charge. The ACR doesn't care. Seems like that could kill one battery or the other.
LinekinBayCD is offline
