SailNet Community - View Single Post - Cost to Replace Chainplates? Should I Walk Away?
post #7 of Old 06-28-2013
overbored
overbored's Avatar
Re: Cost to Replace Chainplates? Should I Walk Away?
its not the cost of the materials it is the labor from the yard that will put the job in the $6k range. no matter which way you choose to cut stainless you will need to finish the metal to a #7 finish ( mirror ) and passivate it if you want to prevent corrosion. water jet or Laser cut will give you just as good a finish as machining in which to start the sanding and polishing process and will cost a lot less. many boats have chainplates made of standard flat bar and only require being cut to length and drilled then polished. you can also buy flat bar that is already polished to a #7. a bit expensive but saves your on labor. if you think you will keep the boat more then ten years then go Titanium. expensive but no polishing is required to prevent corrosion.
"GOLD RUSH" PRINDLE 16
overbored is online now
The Following User Says Thank You to overbored For This Useful Post:
CheckedOutRob (06-28-2013)
