SailNet Community - View Single Post - Cost to Replace Chainplates? Should I Walk Away?
post #9 of Old 06-28-2013 Thread Starter
CheckedOutRob
Re: Cost to Replace Chainplates? Should I Walk Away?
Originally Posted by Alex W View Post
I don't think water jet is the best tool for cutting chainplates. It leaves a somewhat coarse edge that will need to be cleaned up to avoid corrosion. Personally I'd machine then (CNC or manual).
There is no way that a few custom machined bars of 316 stainless steel should cost $10k.
-Hmmmm. I thought water jet cut absolutely razor clean edges? Hence the reason for water jet cutting recommendations on chain plates. I know the need to polish and then electropolish to remove stress risers after the cutting. Is your comment that water jet leaves rough edges conjecture or first hand? Jus wonderin. Thanks.
CheckedOutRob is offline
