SailNet Community - View Single Post - Cost to Replace Chainplates? Should I Walk Away?
post #18 of Old 06-28-2013
SloopJonB
Senior Moment Member
SloopJonB's Avatar
Re: Cost to Replace Chainplates? Should I Walk Away?
The only big expense in replacing chainplates is if they are inaccessible - glassed to the hull, hidden by elaborate cabinetry etc. or if their attaching points are rotted - bulkhead replacement needed and so forth.
If it's simply replacing like with like it shouldn't even get to a boat buck - assuming you turn the wrenches.
Take one or two out and give them to the machine shop to use as templates. They should be made from flat bar, not cut out of plate with a jet. Get them electropolished for a few bucks more and replace - then two more and so on.
I did them on my Columbia 43, which included a fair bit of welding and the reconstruction of a fairly elaborate headstay fitting for less that $1K.
SloopJonB is offline
The Following User Says Thank You to SloopJonB For This Useful Post:
CheckedOutRob (06-28-2013)
