SailNet Community - View Single Post - Rewiring my sailboat
post #14 of Old 06-28-2013
SVTatia
Re: Rewiring my sailboat
Originally Posted by Letrappes View Post
Get your wire from genuinedealz.com. I saw someone post about it a year out so ago and bought from them. Much cheaper than Anchor for the same spec marine grade wire made in Massachusetts if I remember right.
Well, you should shop around: Sailnet, Genuinedealz and Gregs Marine. I'll bet Greg's will have better prices. I am not connected, just a customer.
Originally Posted by Stu Jackson View Post
Basic Battery Wiring Diagrams This is a very good basic primer for boat system wiring: Basic Battery Wiring Diagrams
This is another very good basic primer for boat system wiring: The 1-2-B Switch by Maine Sail (brings together a lot of what this subject is all about)
1/BOTH/2/OFF Switches Thoughts & Musings - SailboatOwners.com
Only difference for you with an outboard is that the negative for your boat is the battery (-) not the engine.
Good luck.
++1 on that
I am half way thru my rewiring project using the learnings I got here and from electrical handbooks from Charlie Wing (highly recommended) and Don Casey.
The trick? plan, plan, plan, do.
1) Draft a diagram based on Stu's links above.
2) Measure all the wire distances taking the wire runs up and downs around furniture into account.
2) Make a list of wire sizes (depends on the distances X 2) and colors
3) Shop around:
  • For wires
  • For connectors and heat-shrink
  • For a crimping tool (Pro's kit was the most cost effective for my project)
  • A good stripper and wire cutter
  • Bus bars
4) Buy
5) Get moving.
Best of luck
SVTatia is offline
