SailNet Community - View Single Post - Cost to Replace Chainplates? Should I Walk Away?
post #34 of Old 06-28-2013
mark2gmtrans
sailing soon
mark2gmtrans's Avatar
Send a message via Yahoo to mark2gmtrans
Re: Cost to Replace Chainplates? Should I Walk Away?
Originally Posted by CheckedOutRob View Post
-Hmmmm. I thought water jet cut absolutely razor clean edges? Hence the reason for water jet cutting recommendations on chain plates. I know the need to polish and then electropolish to remove stress risers after the cutting. Is your comment that water jet leaves rough edges conjecture or first hand? Jus wonderin. Thanks.
Waterjet does have the ability to cut that fine, and should do so, what I imagine they are talking about is plasma arc cutting, which leaves a nasty edge, but it is easily ground off. If the yard charges you $6k for doing chain plates you need to have them shot for theft.
It is good to learn from your mistakes, but much better to learn from the mistakes of others...
mark2gmtrans is offline
