SailNet Community - View Single Post - Cost to Replace Chainplates? Should I Walk Away?
post #37 of Old 06-29-2013
SloopJonB
Senior Moment Member
SloopJonB's Avatar
Re: Cost to Replace Chainplates? Should I Walk Away?
Originally Posted by davidpm View Post
Why do you say that?
Why not. Why would you go to the trouble and expense to WJ cut a chainplate out of a piece of plate instead of simply using a length of correctly sized flat bar?
If you have chains that are some obscure shape then yeah - WJ cutting is great but the vast majority of chains are simple flat bar, drilled as required.
SloopJonB is online now
