SailNet Community - View Single Post - Solenoid switch does not shut off propane
post #7 of Old 06-30-2013
ebs001
ebs001's Avatar
Re: Solenoid switch does not shut off propane
Jiminri, propane solenoids rarely fail "open". They are powered open and mechanically closed by a spring. Find the circuit which powers the solenoid and turn it off - on -off. See if the propane to the stove shuts off and/or you hear clicking. That will let you know if the solenoid is working properly. If the solenoid is working the detector is wired incorrectly. If the solenoid still won't turn off you will need to replace it.
ebs001 is offline
