SailNet Community - View Single Post - Solenoid switch does not shut off propane
post #16 of Old 06-30-2013 Thread Starter
Jiminri
Jiminri's Avatar
Re: Solenoid switch does not shut off propane
Originally Posted by deniseO30 View Post
Call the #$%@# heads that installed the Xintex. You left your boat with the Thing On???
Propane is positively turned off. Valves on the tanks themselves are off and the values that control flow into the separate lines (ALL within the propane locker) are off. I am pretty anal about only have the valves on when I'm actually using propane.
I decided against having the guys who installed it "fix" it because (a) if they screwed it up, I don't want them back and (b) if it is a bum solenoid--and so not their fault--then they aren't close to where the boat is now.
Wiring seems hard to screw up. The schematics that come with the Trident show two white wires that connect with the two black wired on the solenoid.
Nonsuch 30 Ultra #343 1986
West River, MD
Jiminri is offline
