SailNet Community - View Single Post - Heaving-To versus Bare Poles
post #41 of Old 06-30-2013
sailingmum
Re: Heaving-To versus Bare Poles
Have you read the book ?
QUOTE=sailingdog;355929]First of all, it is Larry and Lin Pardey.
Second, heaving to isn't always a good tactic, as it really depends on the boat, the sails, the wind and waves... some boats don't heave to very well. This is often the case with more modern designs, which don't have the keel area to heave to and create the "protective slick" that the Pardeys describe. Modern fin keels often are too small in surface area and often require water moving over their surface to generate lift and prevent significant leeway as well—and don't do much when the boat is heaved to.
What may have worked for the Pardeys in a relatively old design boat, with a full keel, may not be applicable to a different design boat.
There is no one solution.[/QUOTE]
Boatless and Looking 30 - 35 feet.
Winter 2015 Vieques, PR
Professional Cruising Crew 100 Ton near Coastal USCG
Coaching confidence for the cruising sailor.
sailingmum is offline
