SailNet Community - View Single Post - Handicapped Access to Salon?
post #18 of Old 07-01-2013
manatee
manatee's Avatar
Re: Handicapped Access to Salon?
What Mark described is available as a tub lift, operates off water pressure. Only problem is it would block companionway until parked somewhere.
N.B. weighs a ton in 'up' position because it's full of water, has to drain to drop.
What is the vertical distance to be covered?
Do you use a brace or splint to control foot drop?
Depending on your boom, you *may* want to reinforce it. I've read of booms being used as cranes to hoist dinghies, supplies, people & engines, so it is probably strong enough. My main concern is adding a minimum of extra weight and 'stuff'. Don't want anyone getting conked on the head, right?
An ATV winch sounds like a good idea - should be small & fairly weatherproof.
Right now, I'm tending toward the kind of thing you see on the Sea Angel copters used by Coast Guard & Navy rescue teams. Mount the winch near the base of the mast (should be strongest part of boat), ring on boom to attach block over companionway, whatever seat/sling works best. Hand control on a springy 'phone cord'. You might even use the rig as a boom vang to help shape your sail.
"The skipper should be the calmest person on board. It is good for the morale of those around you. However, if everyone around you is frightened then be aware of the possibility that they know something you donít."
~~Dylan Winter,
manatee is offline
