Originally Posted by T37Chef
G,
Your cracking me up...!
The thick base as described is a good thing for electric, radiant, or induction burners, not so good for gas type burners. This is because normally the flame reaches around to the thinner part of the pot/pan and causes the food to burn. This is occurs mostly in pots when making something thick such as a stew, chili, cream sauce, etc. Revere Ware (? Spelling) uses this construction...not my choice, but I cook with gas/propane...indcution when I can
As far as the Teflon issues, I would not feel comfortable commenting on any forum as to the effects of using Teflon for legal reasons. That said, I would never leave a Teflon pan on direct heat without something in it. I would also be concerned about Teflon pans that are chipping/scratched for cooking. Throw it away and buy that cheap one from your local "Crap Mart"
On a similar note, I have an idea...Why not develop "Marine Grade" stoves that have magnetic burners so the pan does not move around! I could also sell a line of "boater friendly" pots and pans specially designed for the stove. Someone please email me if you want to go into business together!
Actually, I think they work pretty well on most marine stoves. I have yet to see a marine stove with a burner large enough to have a flame that is 10" in diameter... so the heat distribution disk is still likely to have a beneficial effect.
I don't know what stove you're using, but I seriously doubt it has a burner that has a flame that is over 5" in diameter at max heat... and with the better cookware, minimal heat is generally all that is needed.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts..
