SailNet Community - View Single Post - Westerbeke/Universal Diesel Problems
post #17 of Old 07-02-2013
messenger
Re: Westerbeke/Universal Diesel Problems
Is there a thermostat or something else somewhere that is shutting down the system?
I have a 30b Westerbeke, 2002 model..3 cylinder, 25hp, red in color with a Mitsubishi block...I see in latest post, it appears we may have different 25 WBs, at least a different paint job...disconnected or erratic connections to oil pressure switch on my model, will cause almost identical symptoms you are describing..been there, done that... cheap fix if that's it...good luck
messenger is offline
