SailNet Community - View Single Post - Solar vs. Wind Turbine.
post #9 of Old 07-02-2013
Re: Solar vs. Wind Turbine.
I've had a wind generator on my Gulfstar 37' sloop since 1991 and wouldn't consider doing without it. I have 3 group 31 Defender batteries (130 a/h each and they stay topped off most of the time. The unit is a Four Winds that is so quiet people come by and find it hard to believe how quiet it is. I bought it with a control unit that measures output and state of charge of the battery. It also has a bump start to get it going in light air, a reverse switch which reverses the field to stop the unit so I can put a lanyard on it when I leave. Similarly it has a spring load governor that deflects when the wind speed gets too high and slows the unit down; and finally it has a 3 stage regulator that keeps the batteries from overcharging. If we're on the boat for days with slight wind I simply leave it running when I go home and the batteries are topped off when I get back. I'm not at all against solar, I just love my Fourwinds which is mounted on a 9' SS pole.
freedoman is offline
