SailNet Community - View Single Post - Cruising Skills/Practice
post #39 of Old 07-02-2013
mark2gmtrans
sailing soon
mark2gmtrans's Avatar
Send a message via Yahoo to mark2gmtrans
Re: Cruising Skills/Practice
Originally Posted by chucklesR View Post
I'd add "learn your boat systems" - and I mean all of them, electrical, electronics, plumbing, engine, drive train, rigging, everything. Sure you can learn it on the way - nothing like learning how to replace a fuel pump while drifting onto a rock ledge to speed up the learning curve.
Take books on all the subjects with you, references help as you won't be able to discuss something that boogles your brain.
Learn what you can fix and what you can't, then make contingency plans and test them.
HAHA, yep, nothing like learning how to fix the little spring that advances the timing on your outboard engine while the tide is going out and pushing you at speed into the Houston Ship Channel...
It is good to learn from your mistakes, but much better to learn from the mistakes of others...
mark2gmtrans is offline
