SailNet Community - View Single Post - Refill Propane?
Thread: Refill Propane?
post #12 of Old 07-02-2013
chef2sail
chef2sail's Avatar
Re: Refill Propane?
Originally Posted by Minnewaska View Post
Even if the tank guage was calibrated and reliable, pressure increases with temperature, so its not a good indication of volume. Chef is right, most accurate at zero.
If the pressure gauge comes after the regulator, its not tank pressure, but regulated pressure. That shouldn't change at all, when pressurized, until the tank is empty. It can be useful, if installed after the solenoid, to see if your system is holding gas after everything is shut off. However, if not testing, you should always burn off the excess gas in the hoses, by shutting off the solenoid with the burner on and letting it burn off.
+1 good point about shutting the solenoid of first and letting the gas burn off
I have to remind the first mate all the time.
Also if you pizo electric sparkers have worn out and you use a firestarter wand, light the wand first before turning the gas on on the stove.
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is offline
