SailNet Community - View Single Post - Spade rudders vs blue water passage making
post #5 of Old 07-03-2013
krisscross
krisscross's Avatar
Re: Spade rudders vs blue water passage making
Originally Posted by capecodda View Post
The culprit in this case was crevice corrosion on the stainless rudder shaft at the bearing. Not an easy spot to inspect. Even if it was hung on a bottom hinge too not sure it would have made a difference.
Perhaps not, but the forces exerted on a rudder are really substantial. Having a bottom hinge transfers the load down and splits it between all hinges. There are not many keel hung rudders that suffer from a broken shaft. Frankly, never heard of one.
Plato
krisscross is offline
The Following User Says Thank You to krisscross For This Useful Post:
DJR351 (07-06-2013)
