SailNet Community - View Single Post - reefing lines
Thread: reefing lines
post #25 of Old 07-03-2013
knuterikt
Re: reefing lines
Originally Posted by svHyLyte View Post
In the lower photo, the forward angle forced on the reefing line by the bull's eye block on the mast immediately below the boom pulls the turning block connected to the cringle strap at the luff forward, causing the line to run over the forward edge of the exit slot on the top of the boom. This arrangement introduces a lot of unnecessary friction to the system and will cause the line to fail at the slot in the boom due to chafe in any extended blow. Eliminating the bull's eye block below the boom will eliminate these problems and create a fairer lead to what I assume is a turning block at the mast base. Single line reefing sustems are great in theory, in practice, not so much.
FWIW...
Removing the bull's eye will create a new problem...
The reefing line will pull the sail away from the mast casing wrong load pattern on the sail.
So if you remove the bull's eye you must move the reef cringle furter aft in the sail.
knuterikt is offline
