SailNet Community - View Single Post - Battery Charging Problems
post #1 of Old 07-03-2013 Thread Starter
csharp56
Help! I am a new owner of a 1984 Catalina. I have one Engine batt which is working fine and seems to be charging when the engine is running. I have two house batterys which only work for a short time and then quickly die after the engine runs for a maybe 15 minutes or so. All batts are in good conditon. I have a Xantrex TrueCharge 20+/40+ Amp mutistage battery charger that is not showing any indicator lights at any time, whether the engine is running or not. I have a West Marine power switch w/ separate house and engine switch. It also has an emergency cross. The engine meter shows approx. 13 volts. The Xantrex meter at the nav station reads approx 13.5. I switch both house and engine on and have also been switching the emergency cross connect on but still nothing and no indicator lights. Any torubleshooting ideas would be much appreciated. Thanks!
csharp56 is offline
