SailNet Community - View Single Post - Bob Perry's take on Wolfenzee's dream boat
post #956 of Old 07-03-2013
Brent Swain
Re: Bob Perry's take on Wolfenzee's dream boat
In this debate I am reminded of the time I went to a steel boat gathering at the Bluewater Cruising Association. I showed up in bluejeans . That was in the early 80s. A guy selling very expensive steel boats bondoed to look like fibreglass boats showed up in a pin striped suit with gold cuff links. People thought "Gee, if he has on a pin striped suit with gold cuff links, he surely must know a lot more about steel boatbuilding than the guy in blue jeans. A friend went to have a look at one of his imitation fibreglass boats which the guy in the suit said was about to be spray foamed. It was welded one side only and you could see nearly the thickness of the metal into the grove where the inside weld should have been The outside weld had been ground flush, leaving only the thickness of a beer can holding it together. She had only a thin coating of primer inside no proper epoxy which is one coat of primer more than Foulkes of Fehr boars, other "BC Professionally" Built boats . I met a KIWI who told me his friend had bought one of these imitation fibreglas boats , he contract specified 2 inches of weld on the stringers every 6 inches. He found his had a half inch of weld every 3 ft holding his stringers in.He went after the guy in the suit ,with lawsuit and when he finally caught him the guy in the suit declared bankruptcy and closed his shop.
No one I have built a boat for in the last 37 years has had any such complaints, even if I do wear blue jeans, and not a pin striped suit with gold cufflinks
Brent Swain is offline
