SailNet Community - View Single Post - Question Regarding Rudder S2 Model 8B
post #8 of Old 07-03-2013 Thread Starter
GaryMasse
Re: Question Regarding Rudder S2 Model 8B
Originally Posted by timangiel View Post
I have an S2 8.0B with wheel steering and I can tell you that mine does not turn 360 degrees. These boats were not made with wheel steering to my knowledge. If you have wheel steering it was an aftermarket add on. Do you know what kind of steering wheel you have? an Edson maybe?
Hello, I tried to locate the name of the wheel but there is no reference. On the survey they simply make reference to the rudder is aided by a rack and pignion mechanism and the shaft to to the rudder runs through a fiberglass tube. Everyone makes reference to having stoppers but I have no idea where this would be located. I have added again a picture of the gear system as well as a top view of the upper mechanism with gears, which are apparently in need of some grease. hopefully this may help someone to point me in the right direction,
Thanks again,
Gary
GaryMasse is offline
