SailNet Community - View Single Post - Going up the mast on a trailerable sailboat?
post #17 of Old 07-05-2013
Hudsonian
Re: Going up the mast on a trailerable sailboat?
You don't need to go to the masthead to work on the steaming light. If it's only 10 or 12 feet above the deck you probably climb or shinny up ( e.g., gooseneck, spinnaker pole bale, etc) Unless you can identify the light model you'll probably need to make at least two trips. One to remove the bulb and a second to replace it.
Hudsonian is offline
