SailNet Community - View Single Post - Going up the mast on a trailerable sailboat?
post #21 of Old 07-05-2013
bristol299bob
bristol299bob's Avatar
Re: Going up the mast on a trailerable sailboat?
SunnyD have you considered making a "test harness"? You'd need compatible connectors and a length of wire. With the mast lowered you could plug one end in to the base on the boat, the other end into the base at the mast. then you can test all day long from the comfort of ground level.
1977 Bristol 29.9
Surprise
Hull #5
Oriental NC
bristol299bob is offline
